I don’t think that grommet should look anything like that
![22BA959B-03C7-47EB-880E-1583B3A6AC34.jpeg 22BA959B-03C7-47EB-880E-1583B3A6AC34.jpeg](https://zroadster.org/data/attachments/179/179469-a53417027a91435819a2f032382650fc.jpg)
![0AF765EA-AA0B-4311-9AF0-F24B74C1089D.jpeg 0AF765EA-AA0B-4311-9AF0-F24B74C1089D.jpeg](https://zroadster.org/data/attachments/179/179471-7a706ab2ba67ec48c5c05531d4dd63b5.jpg)
Dunno whether that hole is due the wearing from the floor or because some has stuck a screwdriver through it.
New ones and Tiger seal required.
Spent yesterday painting seat frames and cleaning/ greasing the screw drives. I knew the bushes needed replaced, this little lot came from the driver seat, nothing left, no wonder the seat moved.
![9B8FA1FF-BF8E-4E11-A93F-385FD33EFDAB.jpeg 9B8FA1FF-BF8E-4E11-A93F-385FD33EFDAB.jpeg](https://zroadster.org/data/attachments/179/179481-6fc445f17a23043d5bb9c63b3d709414.jpg)
I knew I had a problem with one rail of the passenger seat, really difficult to move, it was as I suspected, the limiter was smashed into the cage.
![7CDF13D3-8A02-42D6-A518-A6A73AF58FDC.jpeg 7CDF13D3-8A02-42D6-A518-A6A73AF58FDC.jpeg](https://zroadster.org/data/attachments/179/179483-f1cd3875485ec086f1cfe46ba5b2b9a8.jpg)
Prised it out and reversed it.
Delivery of some Wilwood rotors, long term plan, 300’s with Ali hats.
![23CDE6D3-42E2-425B-AACF-34258F5B7065.jpeg 23CDE6D3-42E2-425B-AACF-34258F5B7065.jpeg](https://zroadster.org/data/attachments/179/179485-12c79a60710ba460ac7daab8e05d55c4.jpg)
Not those hats though, those are off an Audi, redrilled for my Pontiac. When I get a chance I’ll sit down and design some for the Z.
Chopped some steel for the extinguisher bracket to go on the passenger seat. Something weird wwith one of my grinders, the handle is wobbling, with one in Airdrie and the guard missing on the other I just had to get on with it. Cutting a straight line was next to impossible.
![2925BCAF-93B9-465F-BD0D-45F61B417DDA.jpeg 2925BCAF-93B9-465F-BD0D-45F61B417DDA.jpeg](https://zroadster.org/data/attachments/179/179487-c769da9d01da1c46893e4a890b7393fa.jpg)
If you’re fitting something with captive nuts, it’s better to drill at least the next size up. Not because it hides mistakes. If you don’t have any clearance you can easily damage the threads of your fastener and if it’s something that needs a specific torque value, well then, you have a problem.
The blue thing is a Noga tool, takes replaceable carbide blades. They’re wonderful, works on plate or drilled holes. I keep a flap disc in a grinder for the flat bits as it’s far faster, but holes, whirl with the Noga, done.
Brought my rivnut tool back from Airdrie so didn’t have to weld captive nuts.
![AE2475F3-058C-43E3-BD3D-84BE4BD00CA6.jpeg AE2475F3-058C-43E3-BD3D-84BE4BD00CA6.jpeg](https://zroadster.org/data/attachments/179/179489-7acab854f7ed9d39bf7a3e75f59299df.jpg)
I even managed to dimple it neatly.
That black paint is Ronseal straight to metal paint and it doesn’t do what it says on the tin. Water based, so no smell, but it doesn’t dry as quick as claimed, it doesn’t cover very well, needs to be completely dry before overcoating or it pulls. Doesn’t self level so loads of brush marks. I’m glad I didn’t buy silver for the inside, be reverting to Finnegans for that.
Added the heated panels and built the passenger seat up, didn’t take pics of that, there will be loads on here already. Pulling the bolsters in made the back really tight, impossible to tell in the pics but there’s definitely a difference.
![5030403D-E310-4045-8B8A-478714A9B142.jpeg 5030403D-E310-4045-8B8A-478714A9B142.jpeg](https://zroadster.org/data/attachments/179/179491-cc85229c004c83a736427b5fe9fffb78.jpg)
The car has black seats, with a hole in the passenger seat base, I got red covers for £60 quid with theplan to die the base black. Fly in the ointment, once I cleaned the cover before dying it, I liked it, I mean I Really liked it. Plan now is red seats and door panels. There were a pair on eBay up at Gairloch, just a passenger seat now, but I’ll have a go at cleaning and die for the drivers seat.
