2 steps forward, about 5 steps back.
I found a pair of 2.0 shafts cheap, so I could use the 2.8 arms, decided to try paint stripper to help clean them up. Bad move. Screwfix No Nonsense paint stripper doesn’t do much to the rubber coating. At all. Or the black paint, but it does make the rust worse. Taken an entire day just to clean one arm. This was the worst area, which had me initially worried I’d need to cut it and let some metal in. Though it looks rough as a badgers arse it’s solid, cleaned up well, though I forgot to take an ‘after’ pic.
![IMG_4747.jpeg IMG_4747.jpeg](https://zroadster.org/data/attachments/258/258267-b8f91e5e0ac4b5d86f3f6f8b46d19d70.jpg)
You often see front anti roll links on eBay marked as heavy duty, usually quite expensive. Gets rid of the rubber in the system. I’ve looked at them thinking ‘those look like Mondeo’. A pair came up cheap, so I bought them. From the Febi numbers on them, they are indeed Mondeo links.
![IMG_4752.jpeg IMG_4752.jpeg](https://zroadster.org/data/attachments/258/258269-721c08558240975ecc0caab0720a6ccc.jpg)
Also managed to snag another RC042, bottom left pic, now I have the option of a staggered or square setup.
I’ve gotten bored with painting things black, even when they come up as shiny as this.
![IMG_4725.jpeg IMG_4725.jpeg](https://zroadster.org/data/attachments/258/258271-744dc06856b0c1039f2a613755f2aec1.jpg)
So I’ve started using up whatever paint I have lying about
![IMG_4750.jpeg IMG_4750.jpeg](https://zroadster.org/data/attachments/258/258273-5cbf4ef135fd12522321358e58620ccb.jpg)
I think the blue is some old Triumph colour, looks lovely with lacquer on, even though it’ll never be visible.
Not a huge fan of wheel bolts, I much prefer studs, bought several cars over the years with stripped threads, or snapped bolts. Not as easy as just knocking out a stud and replacing it. Cleaning with a tap cleared all this out.
I understand some people think the push rod brackets/support brackets/whatchamacallits, can twist, or flex.
Reinforced with 3 and 4mm steel. Flex now you little feckers.
Oh, and I wonder how many of these I’ve gone through over the years.
![IMG_4718.jpeg IMG_4718.jpeg](https://zroadster.org/data/attachments/258/258279-2b153c3e9f75bf6d6e310e315948e571.jpg)
