A few more pictures and detail on the weekends activities, now that I'm not sat cross-legged on the driveway scratching my head about leaks!
This is the pool of water I found after removing the carpets. My driveway is slightly downhill, so it is about half an inch deep at the end, and then dry at the lower edge of this image. The passenger side was slightly less, but still a pool nonetheless. I dried all those out on Saturday, and then after a bit of rain overnight, sure enough there was water there again Sunday, albeit much less! This is good news though, at least I know it's a leak, rather than that a previous owner used it as a submarine and I have been driving around several litres of stagnant flood water for the last few months.
Fun fact: a blue roll fits perfectly on the inner roll hoop bracket
Saturday night I re-fitted the half-cover and still the pool of water appeared after some rain. I think this rules out the A-pillar or hood drains, since these are under the cover. It
should also rule-out the vapour barriers, since the window and window seals are all under the cover - unless the water gets into the door through the mirror spindles (which stick out from the cover), or some other mechanism? The vapour barriers are hanging off anyway, so I am going to replace the buytl sealant. I think the most likely culprit now is the scuttle drains as advised by
@Duncodin. I'm going to try and sneak away from work a little earlier one day early this week and investigate. I can then leave it to get rained on for a few days while the carpets finish drying indoors and hopefully convince myself we're not leaking before putting the carpets back in.
I jet washed the carpets (including the foam/sponge side), it's not like I could make them any wetter!! Then wet-vacced them before bringing them into the house. Despite my wet-vac of them in-situ after I bought the car, seeing the colour of the water coming away in some spots under the pressure washer was equally satisfying and horrifying. I am quite optimistic that once they're dry and fitted they're going to look brand new. The carpets have spent the rest of the weekend sat around a heater like cub scouts around a campfire
![Face with tears of joy :joy: 😂](https://cdn.jsdelivr.net/gh/joypixels/emoji-assets@5.0/png/64/1f602.png)
. I'd say they're down to about 20% dampness now (Monday morning) compared to when they came out of the car. Few more days to go yet.
I met up with
@PhilH67 last night and collected the black seats and door cards I've bought from him. Quite an incredible set up he has. I have some serious garage-envy going on!
