My first Mig was a BOC, 130 amp, awful thing, the wire feed was plastic, unreliable and inconsistent. Not what you want when trying to learn. Modified it. Second mig a decade later turned out to be almost the same machine rebranded, (once I took it apart!). I modified the feed considerably, upgraded the torch, steel liner, brass cogs, couple other things, gas solenoid I think,
Anyway, it was still rubbish.
At that point I was still trying to run beads “because that’s how it’s supposed to be done”. Loads of distortion, + waiting on the thermal cutout to reset because the duty cycle was rubbish.
My lad got his first Mini age 15, needed Everything welded. I’d asked on a welding forum for recommendations, advised to up the budget a bit and go for a Tecarc Portamig, British built to order. Spec’d down to 15amps minimum. Introduced to pulse welding, on a second, off a second. Not the “correct” way to do it, but little distortion, less holes, much more consistent welds and duty cycle is days.
It’s practice, practice, practice.
There are so many variables, earth quality, current, wire speed, torch angle, travel speed, on time. That’s before you even consider the thickness of metal, or type of weld.
Torch angle, travel speed, and pattern if it’s thick, or angled, can be practiced with the torch off. Moving consistent amounts and patterns with gloves on is probably one of the hardest things to do. There are vids of people taping sharpies to the torch and trying blindfold, bit extreme, but reducing variables gives you less to think about.
I mostly use Tig gloves, they’re much thinner, better feel, I only use thick gloves making something thick. You shouldn’t be touching anything hot anyway, gloves don’t last long if you do.
Oh and setting your helmet up. Strike an arc on a thick piece of steel and adjust the shade with one hand until you can see clearly what he arc is doing, move the puddle about and adjust up/down to get the sweet spot. Note, or mark, the setting. And always keep spare batteries if it’s not solar.
A weld cap stops arc burns to your head!
