One of the links I sent was for a company doing banded steels which were £200ish a corner.Thank you IainP for that link to Imagewheels.
Anyone want to buy me a set of these - I won't say what they cost . . OK I will. +3K a set. Imagine if I bought them and kerb'd one I'd be in tears at the side of the road.
Finding a used set of steels and sending them to the bander is an idea though. But the X1 wheels is my 'plan B'
I saw that. Thanks. It is an option although they want you to send them your wheels. If I find nice wheels then I'd consider it.One of the links I sent was for a company doing banded steels which were £200ish a corner.
Thanks. I'll go visit his utub channel - but get the missus to hide my credit cards because, I assume, "forged-to-my-design" will cost almost as much as the body kit.https://wheelmania.co.uk/ may also be able to help.
They can forge wheels to your design.
as seen frequently on Mat Armstrongs YouTube channel
Would these work?Thanks. I'll go visit his utub channel - but get the missus to hide my credit cards because, I assume, "forged-to-my-design" will cost almost as much as the body kit.
Anyway. Maybe my idea of 17x7 isn't really going to work. Should be looking at 16x7 and tall tyres. something like this. I like the oval holes a bit like the original 507
This is a 3 series F30 wheel. ET31 so will push the rim out around 15mm which is good. But not sure about the bolt holes. 5x120 but I think Z3 bolts might be fatter? Not too expensive. Might buy just one, see if it fits. Stick a tyre on it, 205/65 and see if I like it. Tyre that size will reduce the wheel arch gap by 20mm and give a 6% speedo error - but, as said already, my speedo is 6% out anyway so it'll be spot on... er... m'lud
The ET is 47 so you could add a spacer to move the wheel out. The seller lowers the price for buying 2 or more. A Google search reveals cheaper pricesWould these work?
1 x BMW felge für 3er E46 E36 Z3 7Jx17H2 5x120 ET47 175201 # 22564 | eBay
1 x felge für BMW. Unsere Felgen sind rundlaufgeprüft und technisch einwandfrei. BMW3er E46, E36, Z3. Wir versuchen Ihnen weiterzuhelfen!www.ebay.de
Thanks Ken. They do have that classic look. but that ET47 puts me off a bit. Don't really want to use spacers if I can do it in the ETThe ET is 47 so you could add a spacer to move the wheel out. The seller lowers the price for buying 2 or more
Over thinking. MaybeI think you’re overthinking it.
The original 507 had 185 tyres, I saw one at Goodwood. I’ve seen two replicas at shows this year and they screamed replica from a distance as soon as I saw the tyres.
There are BMW steel wheels 6.5” x 16”, I think et 31, or 33, I can’t remember which. 3series, mostly I think. Mine had one as a spare, maybe 2006?
The recommended wheel for a 185 tyre is 6-6.5” width.
From Powerdog:
A 185 tyre is +10% speed error, 185/70 is +5% error.
Correct. 6.00x16 (the old crossply description) is close to modern 185x16 I think most people who want to use their car daily would use modern radial tyres.The car I saw was on radials, 185-16
It def wasn’t a replica.
I bought them from Realm Engineering .
Are you using spacers?I used bmw winter steel wheels. The offset is slightly more than original and the ‘rim dish’ looks just right to me.
im sure I saw some with the oval holes when I looked around, but wanted the round holes on mine.
There are no spacers and original 12mm bolts will fit.Are you using spacers?
Same wheel bolts?
I've ordered one of the F30 steel wheel (oval holes). I'll put a tyre on it and see what I think.There are no spacers and original 12mm bolts will fit.
Due to my centre caps needing a very unusual bolt fitting (Vw) I had to have VW bolts machined. Down from 14mm to 12mm threads to fit.
you should have no issues though
