Bloody hell, your garage is spotless, you could eat your dinner in there
Did someone say MansfieldNo we went @hardtop..........sorry I mean dutch !!!!
(And he still has another Mansfield trip to do)
Empty the paint tin and rub it in with a soft broom. You will do a normal garage floor in 15 minutes tops. Tip of the week …….. don't start at the doorFloor painting is much easier though. Poor and roll.
Yeah, a bit like sawing off a tree branch eh mate?Empty the paint tin and rub it in with a soft broom. You will do a normal garage floor in 15 minutes tops. Tip of the week …….. don't start at the door![]()
If the glue isn't strong enough you may want to consider solder, great work by the wayOne hiccup, fingers crossed, is now sorted.
Looking at where the stud broke off, its been missing for some time.
So small wire brush in the drill and cleaned up the area to get bare metal exposed.
Using this, as was recommended for use on metal, but only time will tell if it is any good for this application.
And a bit of pressure to hold it tight for 24 hours!!!!
And I remembered to put a big thick wad of kitchen roll under the clamp on the other side
I also made a test piece to test strength of glue. I leave it for 24 hours then try to break it apart
Thats it for today.....dont like to work too hard, and off out for a pub lunch that I will try to co,n my brother into paying for !
Nice work Malc you must be very pleasedWell done Malc, it's been a great read. Bet you're quite chuffed to be nearly at the end![]()
