Another day and more stuff removed !!!!
Started by pulling all the plastic covers off, removed the plugs and carefully took the wiring out.
Got it this far and it got stuck.....
Then reallised I should have disconnected the loom from the holding clips
Pulled it all back with some stiff earth wire removed the clips and then with a bit of jiggling got the loom out.
As advised by
@Sean d , undid all the wrap ( most of which was falling off) and checked all the wires from down in the boot through to the plugs and other than an inline connector joining two wires everything was ok.
Once checked re wrapped the wires with electrical tape.
Didn't assemble the new boot lid as not sure if the paint shop would rather have the parts off the car.
One thing that was annoying is that the 3rd brake light lens had previously been damaged ( by some oik rounding off the hex head screws and plus it was held in with a black gloop
So I have lost my roadster decal as I cant reuse it !!!!!
Did you know you can fit a Z3 bonnet and boot lid into the back of a Kia Rio???????
You can when I get at it with an angle grinder
And its final resting place....our local tip
A good tip for anyone doing this in the future ......put something on the front bumper shocks as they bloody hurt when you walk into them.
Not a lot I can do now until the parcels with the new bits arrive.
I think that is all the stripping down complete....so every thing from now it will be putting it all back together
