From a legal point they should be mounted on a vertical surface not flat on the bonnet.That's good to know, I like the stick on plate, it opens up the grill area. Anyone tried this on a Z3?![]()
Not quiteFrom a lemade
So you could argue that they can't be mounted where the cooling of the radiator by air is impeded. Might work for a kit car, but not convinced it would work for a Z3. Some early E types had it mounted on the bonnet for this reason though I believe. Best leave be.Not quite
'Legally' they have to be mounted
'vertically or, where that is not reasonably practicable, in a position as close to the vertical as is reasonably practicable'
https://www.legislation.gov.uk/uksi/2001/561/part/II/made
Interesting- could be mot pass but the legislation requires it to be vertical?nothing in the new MOT check about mounting
https://www.mot-testing.service.gov...dentification-of-the-vehicle.html#section_0.1
Only says it has to be secure. Doesn't even mention being the right way up .nothing in the new MOT check about mounting
Thank you. It may be slap-dashbut it is unique. And made by my unskilled handsGood on you it looks great
Thanks Ian and I agree about the front plate. Will drop it lower at least for now.Love the "minimalistic" look, bet people give you a wide berth!!
Front plate needs moving though!!!
