Best of luck mate, I feel for you as I'm in a similar place with my black zed. I did a head gasket change and top end rebuild and thought everything was ok. The car ran great for about 500 miles then it started miss firing. The problem I have is cylinder 5 keeps oiling up. If I clean the plug the car runs great for a while then fouls again. I did a spark plug shuffle and again, it runs great then number 5 oils up again.
I'm suspecting piston rings or the nikosil coating on the cylinder walls. If it's the nikosil coating, then the engine is f****d.
I'm not sure what I'm going to do next. I might sell it on as a project, might fit another engine or might break it for spares. I've spent a few quid on it over the last 12 months but I've done everything myself so haven't had to pay anyone other than for reconditioning my cylinder head.
If your problem is the head gasket it's a relatively easy fix, it's not too expensive and not a difficult job if you can do it yourself. Good luck.
