Was your friend lying down on a skateboard to get that shot?
Great photo, have you changed the brake fluid for higher temp fluid? The OEM brakes are really very good with fresh fluid and a decent set of pads.Went to the ring!
It needs work i had to stiffen up the coikovers because it was floating all over the place, after that it felt dialed, except for the brakes fading like hell. Need to mount the m135i brakes!View attachment 76633
yeah well I know but i like the look of the m135i calipers alot haha so It's more the look and then a bit of performance.Great photo, have you changed the brake fluid for higher temp fluid? The OEM brakes are really very good with fresh fluid and a decent set of pads.
They do but it's not a simple bolt on job.any idea if the M135i calipers fit? they look great
Seems to be par for the course when trying to fit monoblock calipers to the z3 / z4They do but it's not a simple bolt on job.
Do you have more information on the install?They do but it's not a simple bolt on job.
Another coupe owner fitted these but couldn’t find anyone who made brackets. It took him along time to get some made so they fitted.Do you have more information on the install?
Also tried to install the buckets, but the freaking sidemounts don't fit the seat brackets... have to get new ones on monday I suppose
I checked with INPA it said it was the fanAlso, our engines have electric water pumps using INPA you can see if its making a sufficient flow or even logged a code. They are prone to going.
Looks like your on the right track then. nice work.I checked with INPA it said it was the fan
EDIT: + it doesn't run hot when i'm driving
And the fan also doesn't turn on when I turn the AC on
