not sure with the airbag, will it not just clear the code or does it come back?
but well done with the roof motor,,![Thumbs Up :thumbsup: :thumbsup:](/assets/thumbs_up.gif)
I've currently got an Airbag issue on my car. Will post back and also watch for your posts.hi,can clear it with the scanner,but comes back next time car is started
That's great, hope it's the end of it. I'm fairly confident my AB light issue is now gone too!everything back in today,and cleared the airbag light,which is now staying off,so i am presuming the passenger seat occupancy sensor was at fault,and the bypass resistor i got off ebay has sorted it![]()
If so, it seems like with the oil reservoir inverted it will dump oil once you break the motor loose, or am I misunderstanding?You can separate the motor from the pump by removing 2 allen bolts, but do this with the pump downwards and break the joint nearest the motor or you will lose hydraulic oil (ask me how I know)
