A few bits done today....
Started with the bumper cover....just a bit more rubbing down.....
Then cleaned off and went over it with a tack cloth. ( see really professional...
Then a bit of primer....
All good ....until I noticed one of the inserts that I put in was not straight....and didn’t take much to remove
![Arghh :arghh: :arghh:](/styles/default/xenforo/smilies/arghh.png)
The main reason was that the hole had been opened out a bit and the insert wouldn’t crimp down on to it properly....
So had to come up with another solution, and I didnt want to use a larger insert..... so came up with this...
I got another matching insert, And put an external M8 thread on it. Wasn’t easy and the first one didn’t go well, but the theory was fine
. With a bit more care, I managed to do it and this was the result...
Fixed it in with a washer and an M8 nut ....and a drop of threadlock.....
I’m not sure that the new radiator is the right one for the car though.....
Andy said it was a Z3M special when he charged me £250 for it ...........only joking
Its a mates, and he asked if I could rub it down as he was so impressed with what ai did to the bumper.....MMMMMMM!!!!!!!!
I checked the nut on the front drivers side hub ( couldn’t remember if I had torqued it ), bent the tabs in
, and put the cover on.
Couldn’t do the bumper top coat as it got too windy and the sun went in....plus I have to drill 4 holes where the lower grill tabs have broken off.
I will need to get some thin self tappers as not a lot of material thickness to play with. Needs to be done as I’m sure the lower grill will vibrate otherwise.
Might order the cooling bits tonight..water pump, thermostat, and a new belt.
It may need a new idler but as it didn’t seem to be making any noise when I had the engine running, I will leave that for now.
