So Jigsaw puzzle time…..
first find somewhere where I can work on it ….Dining room Table is fine
grab some cushions and the cats bed to protect the new paintwork…..
First thing to be fitted is the aluminium casting… and I did Remember to remove the two large bolts to make it easier later when it goes on the car.
Went in fairly easily …it didn’t sit right down at first but the grommets hadn't located over the two little bosses properly
Then 14 ( I think ) plastic push in studs and two plastic rivets to fix it in. Really tight but put some washing up liquid on the and that seemed to work …..
but not before two had bent tapping them in
Had to tap them in ….. couldn’t just push them in. But luckiily I am awash with spares at the moment so liberated 2 from the bumper in the back garden ( from the breaker) and soon all 14 were locked in place. The two rivets are for the two holes right at the front
so onwards and upwards….
The fitting of the.new bottom grille :::: and after few issues it is in place and looks ok , but was not easy…..
first, just getting it to line up on the spigots took ages as all the ones that were there had over time been bent, flattened and damaged…had they been pristins then the grille would have probably fitted straight in.
Where four spigots had been broken off, a while back I did drill them all with 1.5mm holes. Ready for this day !!!!
I also had picked up some 2 mm self tappers and washers
its not quite sitting down here but the spigots only just came through the holes
the four holes that I had drilled worked ok and the self tappers didnt break out of the side of the plastic
I only managed to get 2 or 3 of the new grip washers to hold in a couple of places and after a bit of a think, because they are dished I tried one upside down and used a small socket to tap them on……surprisingly it worked so I did the same thing to all the others…..
not pretty, but functional…..
so on to the fog lights….
I had alreadty fitted four anchors as the originals has rusted and had also damaged the plastic… so in 3 case just put a bigger hole though and fitted rivnuts in the normal way….. the fourth one was a lot more damaged so I ended up putting a thread on the outside of the rivnut and using a standard nut to fix it in.
but both fog lights fitted straight back in and I clipped in the finishing piece.
Number plate straight forward , used the plate holder as a template fot the 4 holes , then with new self tappers and plastic screw covers put it back together
so now it can go back on the car…… but at some other time …….( got a gig later)
For now, it can stay on the table and the cat will have to find somewhere else to sleep. .
