Dxbolton
Let’s see your handles and locks?
Open the door, open window. close it with the handle lifted.My plan (hope) is to connect a new handle to the skin that just pulls on the original z3 handle. No messing about with linkage inside the door.
Reading this last few days about deadlocking. Don't want deadlock.
So, anyway. I just went outside and lifted my z3 door handle all the way up before unlocking with the remote central locking. Worked fine.
So it looks like the position of the outside door handle, even if it hasn't returned to its rest position, doesn't cause a deadlock? Or is my lock not behaving as expected.
The idea of rigging up a handle that just pulls on the old one. Is this idea immune to deadlock?
Opening from inside? (Locked in?) I thought the deadlocking we we were talking about is that the remote central locking would not unlock the car and I'd be "locked out". But Locked In is also something I need to check of course.Open the door, open window. close it with the handle lifted.
Lock car,
Try opening from inside, it will be deadlocked
Until you release the outer handle, it shouldn’t open.
So under what circumstances would a Z3 be 'deadlocked' and what triggers it?Deadlocking is that you cannot open the door, inside, outside with the key in the ignition. you can try what you want but if the car is deadlocked the only way is to use the BMW key in the outer door lock or lift the lever marked in Dxboltons post above.
Do not confuse deadlocking with simply locking the car with the remote they are very different.
That’s a Pontiac Grand Prix handle, they’re still available new I think.The original 507 handle has an interesting action.
I imagine it lays flat to the body and you press the button and the lever pops out.
I think it was @Piran who posted a picture of a pontiac handle that looks to have a similar action.
I might see if I can find some info on those to see how the action works
Fiat Barchetta also have a flush 'pop out' lever too and maybe easier to get than pontiac. But it all comes down to the action.
If you do go lectric please come back and tell us what solenoid you used.Knew I had a link, my Fiero has the most hideous handles possible and I was considering those, now probably going to go electric with a TVR style switch under the mirror.
The fiat ones are much cheaper and easier to get hold of - so I'm going to try those, I know someone who successfully used them on another tribute but I'm not sure that had the extra door skins so we'll see.The original 507 handle has an interesting action.
they seem to be quite expensive thoughThat’s a Pontiac Grand Prix handle, they’re still available new I think.
New ones, yes, I expect so, I’ve seen them as low as US$20 on eBay, about £40 inc carriage to UK.they seem to be quite expensive though![]()
If you look at the photos, if the big gold lever does not FULLY retract to its closed position, the central locking will not allow the car to open.So under what circumstances would a Z3 be 'deadlocked' and what triggers it?
Steve. @10stb You building a 507? Show us your handles?Hi Piran, making good progress I see. Well done
How did you manage to get the boot to central lock. I've just fitted my handles (went for classic mini) and central locking works great with them.
Currently have the boot to open normally with the handle but would love to link it to the central locking.
I opted for external triumph boot hinges and a bonnet stay from a vw polo as I was concerned about flexing with gas struts.
Cheers
Steve
