Dxbolton
Now that I know they were alfa handles, I wish I'd looked at the fiat barchetta ones. Push button moves the handle from being bodywork flush to an external
Is that how the barchetta handle works? I thought it was the button that undid the latch and the lever just pops out as something to hold to swing the door. But you're right. The action kind of looks similar.Now that I know they were alfa handles, I wish I'd looked at the fiat barchetta ones. Push button moves the handle from being bodywork flush to an external lever type handle. If you were able to rig this up to pull the existing zed handle, it would be similar to the original 507![]()
Ordered one MGB handle yesterday from EBy and it arrived today. Movement is around 17mm which ought to be OK depending how it's mounted.When you pull the lever there was 10mm of movement which I felt was not enough. Current handles is near 15mm which works fine
They look nice, would be interested to hear if anyone tries these - it doesn't look like a lot of movementDon't try to find BMW 507 door handles. Be like looking for unicorn poo.
Look instead for BMW 700 handles
https://www.ebay.com/itm/325565525602
I think the button just makes the lever pop out. Then the lever is what moves the plunger to push a strike plate.They look nice, would be interested to hear if anyone tries these - it doesn't look like a lot of movement
I'd love to see you do some stuff for the 507I designed a set of handles for my DNA 250 to look like the originals on the outside but to interface directly with the Z3 lock system on the inside. I did this because of the same issues that have been raised in this thread such as dead locking and insufficient throw, and of course having something that is faithful to the original. One thing that I've since discovered is that builders of Tribute kits have followed a different handle path to the DNA crowd. Tribute builders tend to use the original Z3 handle with a plate attached to it whereas the DNA crowd remove the handle and go directly to the Z3 lock release lever (By way of a pulley).
Deadlocking is a scary thing to have happen and I believe it is more prevalent in system which retain the Z3 handle in the path. My reasoning for this is contained in an overview in the reference library section on our website Grassbank Conversions
I'm seeing the same issues arising now with the 507 handle so I've started the design of a 507 handle which will look and function like the original 507 handle on the outside but which will use the same system that we developed inside to operate the Z3 lock lever. There are two versions of the 507 handle, I think the original has a curvy style push button whilst the second version is a bit squarer, the second version was also used on the BMW 700. I haven't decided which version to develop yet. I prefer the style of the Mk1 but there might be scope to do both.
It's going to be a couple of months before I have anything to show but if anyone is interested then please get in touch through our website. Building the kits is challenging enouigh without the added hassle of solving the same problem over and over.
Door handle was posted today. Just sent it 1st class. I hope it doesn't take too long to reach you.I'm expecting a door skin from Chris and a handle to work on from Ian (Duncodin). Looks like I'm in for a busy time![]()
I do have another off these driver's side handles. Better than the one I sent. If you break the 1st one and need another for final testing just let me know and I'll send that one too.I'm expecting a door skin from Chris and a handle to work on from Ian (Duncodin). Looks like I'm in for a busy time![]()
