further update..
the new radiator was faulty!..leaking from the side of the expansion tank after barely 2 minutes..
on the + side compression test done and the reading were 200-210 psi on all four cylinders, still no milky oil and still no oily coolant, this all but rules out the head gasket...
but have decided even if it turns out to be that it's a job I can handle with barry's help and as rich said in an earlier post with parts and skim and pressure test can probably do it for under £200 ..
eurocarparts have ordered a replacement rad FOC and are throwing a 5 litre bottle of coolant as I mentioned to them that I shouldn't really have to pay again for that.
I will also enquire about the 80c fan switch and if they have it I may well do the fan delete Mod whilst i'm in there..if guys in the southern states of the US are running this with no problems it should be perfect for our cooler climate I have always wondered why we had two fans especially in europe, it seems like overkill.
as my car already has AC electric auxiliary fan its just a simple job of replacing the current rad fan switch with OEM part no 6131 8 376 440, this ensures the electric fan comes on 10c cooler than normal and will be more than enough on the 1.9 engine.
on the plus side it should free up some ponies take stress of the water pump bearings and most importantly eliminate the possibility of pieces of plastic flying around the engine day at frightening velocity.
We also got to the bottom of Barry's problems and the car now has a working coolant system with no leaks, it turns out it was the radiator cap!..we have ordered 2 new ones form euro's to be picked up with the rad today at £5.99 a pop its just another thing we can rule out if my car still doesn't stabilise..we will also fit the new hoses.
interestingly the hoses (from BMW Guildford) cost more than the Radiator from eurocarparts...which we hope works this time..
I may just fork out another £50 for the Hella if they have it in stock..
we also got Barry's seat bushes fixed and the car is now ready for it's MOT..he was chuffed and can't wait to get it on the road.
as of yesterday between us we have completely overhauled 2 M44 coolant systems one manual and one Auto and we have learnt loads along the way..!
best to all from Joe and Barry Z Roadsters resident coolant system specialists!
