morning gentlemen..
bad news i'm afraid....
we fitted the new rad and we still have the leak..
work so far
2 new radiators neither of which cured the problem
new top and bottom hoses
tested with 3 different rad caps
thorough inspection of all other hoses they are ok.
system thoroughly bled, although an improperly bled system would not lead to leakage but overheating which strangely according to the temp gauge didn't happen...its buffered I know but this means that the engine is running within normal temp but with high pressure..
the leak appears to be coming from the radiator cap/expansion tank area and when we got back from a "spirited" drive steam was coming from the cap and coolant was leaking all over the floor, this implies that we have to much pressure in the system.
remember we have done a compression test and the figures were
1) 210 psi
2) 200psi
3) 200 psi
4) 207 psi
these figures are very healthy and shouldn't be what they are with a head gasket failure, and the car pulls like a train (alright a 1.9 train
) and is responsive and sounds great!..
however the leak persists...
no milky oil, clean coolant, clear exhaust, no bubbles in the coolant with the rad cap off..
re the fan delete I will be happy to do a wiki..that works brilliantly well and butt dyno reports improved acceleration and a more linear curve all the way to 6500 rpm...generally more peppy and responsive, a brilliant mod and if you have the AC fan in the car already, really simple to do.
if not ebay has a multitude of used BMW electric AC fans starting from £20..we are going to do this mod on Barry's car so when done we will do a combined WIKI article for conversion from a car with and without pre-existing electric fan including wiring schematics for retro fitting a fan.
rich, do it! if you have the AC then all you have to do is fit the radiator fan switch from the M43 ,part number 6131 8 376 440, it will require a minor rad top up and bleed..estimated time for the job 20 mins including making a cuppa!..
available from euro car parts for £21,
you will have to slightly modify the connector but its obvious where and done in 30 seconds with a stanley or similar..
re this leak
thoughts? however bizarre..at this point i'm prepared to believe I have a family of Hobbits living in the coolant system hiding from the queen of Narnia...![Woot :woot: :woot:](/styles/default/xenforo/smilies/woot.png)
i'm stumped is what i'm saying...
worth remembering for anyone joining the thread late , the car has done 72k overall 27k of those in the last year since I have owned, with not a SINGLE engine or cooling issue , this is all post an overheat and coolant loss due to a shoddy repair of the heater matrix hose with a hose connector.
btw I removed that connector and there was enough hose to just re-attach to the inlet point ,took 3 minutes..somebody has been a very lazy a*rse.
i'm afraid Gents this is starting to look like a head gasket...![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
thoughts on a postcard please.
work so far
1) 210 psi
2) 200psi
3) 200 psi
4) 207 psi
re this leak
