Please can I have some help
Shelly
Norfolk
Z4 2.0 20i M Sport sDrive
I’ve got a problem with my poor Z 🥲
I was driving home from work ( 2 miles )
Engine started running rough , as I pulled into the drive the engine cut out , engine management light came on ( yellow ) , after that the car would start, but still rough , the following morning, the car would turn over but will not start at all , up until Friday the car ran like a dream with no problems.
Anyone got any ideas what is wrong with my Z .
Thank you 👍
Si
Sittingbourne
Z4 E89 20i Auto
Oh no.. sorry to that Shelly, I can‘t help I’m afraid with the mechanicals hopefully there will be someone to offer some advice…
You need to get some one local who has a code reader to hook it up and see what's going on Shelly. No good guessing.
Shelly
Norfolk
We’re got a code reader , but it won’t work because the car is completely dead 🥲
Won’t it read codes with the engine off?
Crank or cam position sensor(s) gave up maybe?
Timing chain failure is a possibility.
motco
Chilterns
Z3 2.2i Sport
Chain slippage maybe. But not breakage as that is catastrophic and complete, not causing rough running. A slack chain might jump a tooth or two though. But why would that leave the engine apparently 'dead' electrically? We need Shelley to elaborate on 'dead'. Re-reading her initial post suggests electrical systems are still on but there's no firing so the code reader should work.
motco
Chilterns
Z3 2.2i Sport
Another thought. My son's Z4M had a habit of running rough from time to time and it was found to be coil pack failure. Quite what effect a non-igniting cylinder would have in the engine management system I don't know. Maybe it would cause a shut-down to protect the engine?
Chain slipping is still “failure” is it not. That early 4 cylinder engine was known for chain guides breaking, allowing chain misalignment where the engine still ran, all be it very poorly. We obviously need more info before we get to the bottom of it.
Shelly
Norfolk
The engine is trying to turn on very slightly, but nothing there , were going to get someone to come and have a look at it , a mobile mechanic when he can fit us in , 😢 Allan has charged the battery, and
googled maybe what can be wrong with it , Allan has cleared the faults with the code reader as we have electrics working in the car . Hopefully the mechanic can come round soon , thank you all for your help 🌞
Zephyr
did you get a reading of the faults?
Please don say that they were P0008 or P0017
Shelly
Norfolk
Yes these are the numbers ……
c5a0
3887
6030
Z3 project and E89 Z4
c5a0
3887
6030
All those codes point to low voltages. So either your alternator is not charging properly, or the battery has died.
Obviously a new battery (needs coding to the car) is the first step.
E89s really do not like low voltages. It can cause all sorts of random faults to appear. The electric handbrake is a famous one.
Shelly
Norfolk
We tried to jump start the car , and it turned over very well , but the car just wouldn’t start 🤔
