Some interesting results (grab your anorak
First of all, running temperatures. It has been hot today (28°C)
Times are in minutes. I drove for a short while and dropped the missus off at work and left the car idling for around 90 seconds (07:22 - 09:05). Went for a quick blast until about 17:02. Slowed down to cool the car until I got home at 24:27. Sat idling until 26:15, then switched off.
Points to note from the graphs:
1. Intake Temp: Is fairly stable when the car is moving, but increases dramatically when the car is slowed down or stopped. The intake temp never dropped, so the key is to not allow it to rise in the first place.
2. Oil Temp: The magic 60°C mark is reached after around 7 minutes of very steady driving (<3,000rpm). After that the oil temp continues to rise even if the car is idling. The peak temp when the engine is running is about 110°C, but increases to 115°C immediately the engine is switched off.
3. Coolant temp: The coolant was fully warmed up after around 3 minutes of steady driving (<3,000rpm). The temp remained steady at 79°C until the engine was left to idle and then the temp increased and continued to increase after I started the blast to almost 90°C. It then started to cool. There is obviously a lag between the extra air going through the radiator and the coolant being cooled. As the car was driven harder, the temp went varied by around 8°C (83°C to 91°C). At the end of the blast, the temp dropped back to 83°C, but rose again as the air flow through the radiator reduced. When I sat idling at the end of the run, the temp dropped to around 85°C. The coolant temp increased after the engine was switched off.
4. Conclusions:
a. It's very hard to reduce intake temp once it has risen.
b. Switching off or idling INCREASES the temps
Next, the cool-down graphs...
The x-axis is the time of day. The engine was switched-off at just after 1PM. Just look at how long it took for things to cool down.
1. Intake temp: It rose to 64°C before taking nearly 4 hours to drop to its "switch-off temp".
2. Oil temp: It rose to 115°C before taking 15 minutes to return to its "switch-off temp". It took 30 minutes before it had dropped to a similar temp to the coolant. The temp was 60°C more than 3 hours after switch-off.
3. Coolant temp: It rose to 91°C before taking 30 minutes to drop to its "switch-off temp". The temp was 60°C more than 3 hours after switch-off.
4. Conclusions:
a. Intake temp rises very quickly after switch-off and takes a long time to drop.
b. Oil and coolant temps increase after switch-off and take 15 and 30 minutes respectively to return to their "switch-off temps".
c. Oil and coolant remain very hot for many hours after switch-off.
Homework:
I need to do a lot of work to prevent the intake temperature from rising so high - hot air is less dense and has fewer oxygen molecules in each cubic metre. The more oxygen molecules going into your engine, the more fuel that can be burned, and the bigger the bang
