I am surprised that the Data Logger didn't pick up that you need to have a crap to lessen the weight of the vehicle, it does everything else! ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I made an extension wire for my diagnostic cable and run it into the cabin from the 20-pin port under the bonnet.@Pingu May I ask a silly question? Where are you plugged into to get these results? Under the bonnet or under the steering wheel? If under the bonnet can you please show the setup as I would love to pinch your diagnostic setup and have a go and see what results I can get on my 3.0 auto. I have all the hardware and software. Cheers, mate.
That's really inter meeting and id be keen to try it on my car.I made an extension wire for my diagnostic cable and run it into the cabin from the 20-pin port under the bonnet.
Here's a video that I made "especially for you".
Grab yourself a coffee as it's 15 minutes of the most exciting stuff on YouTube since GangNam made a cat video...
If you are interested, here are the files...@Pingu this is brilliant and thanks a million for that. The sound of the S50 is magical. I will try this out on the weekend! Is it possible to export and import macros?
I agree, but for different reasons@Pingu this is brilliant and thanks a million for that. The sound of the S50 is magical. I will try this out on the weekend! Is it possible to export and import macros?
Bookmark it, its then easy to find when you need it.Could do with a sticky in the knowledge base to make it easy to find in the future. A bit beyond me but like to try it mine at some point.
I agree, my 66 mustang has a machanical ignition and comes on like a. Bear at anytime compared to an electronic. Also putting 271HP from a 289cu in v8. Latke slow off the line being an auto but comes to life from 200-7500 rpm! JIMIgnition Angle
6.4
5.2
The ECU does not know what you are going to do. It only knows what you have done. Consequently, the timing of the next spark is based on what has just happened a few milliseconds earlier. If you set the revs to 4000rpm, the ignition is fully advanced and ready for action. If you gun it from idle, the timing of the spark needs to advance - this takes time (as you can see on the 6.4 curve).
Mechanically, there are no gains to be made, but if it were a mechanical distributor, you would want the ignition to be held against the spring, so the force to move the points would be acting in your favour. As far as I am aware, electronic ignition with no moving parts just happens. The only way to improve it would be a remap.
You can log in any time as long as you fix it up for me! HahahaIf you are interested, here are the files... I could have installed an autoexec file that takes over your computer.
